I have a ford explorer 1999 that will not idle on a cold day unless you give it enough gas to stay in 1500-2000 RPM range.
It has the code logged into the cpu that suggest the Mass Air Flpw sensor and the Oxegen sensor are the issues. I have replaced the Mass air flow sensor and the idle control sensor but the problem still is there. I understand that it has two oxegen sensors is that correct??? What do you think the problem could be???
Jan 16, 2009 at 5:36 PM
