1998 Ford Explorer Timing Chain
1998 FORD EXPLORER
187,000 MILES • 4 CYL • 2WD • AUTOMATIC
BATMANFORHIRE79
I found a piece of the timing chain guide inside my oil pan when I replaced the oil pan gasket. Should I be concerned that the timing chain will break and ruin my motor? There are no noises,rattles, or difference in the performance. I also have not idea how long it has been floating around the oil pan.The piece is about 1 1/2 inches long.[img:15635c3dc3]http://www.2carpros.com/forum/automotive_pictures/590410_P1020448_1.jpg[/img:15635c3dc3]
Nov 8, 2010 at 1:45 AM
  • 110,244 POSTS
It should be replaced. It could cause other problems with the chain / components.
Nov 8, 2010 at 2:25 AM
BATMANFORHIRE79
Thank You
Nov 8, 2010 at 2:38 AM
  • 110,244 POSTS
Glad to help. Let me know if you have other questions.
Nov 8, 2010 at 2:49 AM
