When temp drops below 25 degrees F, car will start and begin to ldle and then stops. To insure the car will run I must feather the foot feed for a few minutes before car will idle on its own. Check engine light gives codes 0171 and 0174 (lean on left and right banks). I've replaced the IAT sensor (inlet air temp sensor), cleaned tjhe MAF sensor. What else can I do? What should I check?
Nov 1, 2008 at 5:54 AM
