1998 Ford Explorer ABS sensor
DENNIS L BROWN
  • 1998 FORD EXPLORER
  • V8
  • AWD
  • 139,549 MILES
How to replace right front sensor
Tuesday, October 26th, 2010 AT 5:43 PM
SATURNTECH9
  • 30,869 POSTS
REMOVAL
Disconnect the battery ground cable.
Remove the rotor shield.
Disconnect the front anti-lock brake sensor electrical connector.
Unclip the front anti-lock brake sensor wire from the vehicle frame.
Remove the bolt.
Remove the front anti-lock brake sensor.
1 Remove the bolt.
2 Remove the front anti-lock brake sensor.
INSTALLATION
To install, reverse the removal procedure.
NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
There you go.
Tuesday, October 26th, 2010 AT 6:25 PM
