1996 Ford Explorer Front Tire Lean and Pop
WBCOOK5
I have a 1996 Ford Explorer Sport. 4.0 V6, automatic, 4WD. The vehicle has approximately 130,000 miles on it. The front tires lean in to the top. This causes the tires to wear on the inside, and the vehicle pulls to the right a lot. Also, when i turn the wheel sharp in either direction, it makes a loud popping sound. What could be my problem, and approimately how much should it cost have this problem resolved?
Nov 18, 2007 at 8:40 AM
MERLIN2021
  • 17,250 POSTS
Popping sound? Check your ball joint, upper and lower, FAST!
Nov 18, 2007 at 8:53 AM
Suggested Repair
Inspect the upper and lower ball joints promptly because of the loud popping when the steering wheel is turned sharply. No repair cost was given.
Conversation Summary
The owner of a 1996 Ford Explorer Sport with about 130,000 miles reports front tires leaning inward at the top, inside tire wear, a strong pull to the right, and a loud pop when turning sharply either way. The expert advises checking the upper and lower ball joints immediately.
