1996 Ford Explorer Shift Solenoid A ckt Performance or Stuc
TAPS70
  • 1996 FORD EXPLORER
Transmission problem
1996 Ford Explorer 6 cyl Four Wheel Drive Automatic
Hi I;m getting a p0751 code Shift Solenoid A ckt Performance or Stuck off. Do anyone know want it is and how to fix it. My o/d drive off light was flishing and went back off. But I got the code.
thank you taps70
Wednesday, July 7th, 2010 AT 6:28 PM
  • 109,755 POSTS
Hi:
There are a few different ones. I need to know if you have been having trouble when the trans has been shifting between any specific gear.
The shift solenoids are located on the valve body in the transmission. When you remove the trans pan, you will see them. Here is a picture of their locations.
https://www.2carpros.com/forum/automotive_pictures/249084_5_17.jpg
Wednesday, July 7th, 2010 AT 11:36 PM
TAPS70
All my gears is working I had my o/d off light come on. Win I turn the car off and back on the light went off. But I got the code.
Thursday, July 8th, 2010 AT 12:29 AM
  • 109,755 POSTS
If the transmission is working fine presently, have the code reset and see if it comes back on. It could have been a once in a lifetime problem.
Thursday, July 8th, 2010 AT 12:59 AM
TAPS70
Ok I'll give it A try thank you for you time.
Thursday, July 8th, 2010 AT 1:04 AM
  • 109,755 POSTS
I'm glad to help, and that is what I would try at this point. Chances are it will be fine. Let me know if you have problems or other questions. Just continue to add to this post and I will receive it in my email and get back to you the same day.
Take care and thanks for using 2carpros. Com
Thursday, July 8th, 2010 AT 4:42 PM
