HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Drivetrain
Wheel Bearing
Replace/Remove
SPONSORED LINKS
1996 Ford Explorer front wheel bearing
GSELERT
MEMBER
1996 FORD EXPLORER
6 CYL
4WD
AUTOMATIC
19,600 MILES
How to change front wheel bearing
Tuesday, March 30th, 2010 AT 1:26 PM
BLUELIGHTNIN6
MECHANIC
SPONSORED LINKS
Tuesday, March 30th, 2010 AT 2:33 PM
GSELERT
MEMBER
1 POST
Thank You Very Much
Tuesday, March 30th, 2010 AT 2:48 PM
Please
login
or
register
to post a reply.
Related Wheel Bearing Replace/Remove Content
2002 Ford Explorer Rear Wheel Bearing Replacement
Labor Hours To Replace Rear Wheel Bearings
Asked by
labz
1 ANSWER
2002
FORD EXPLORER
VIDEO
Instructional repair video
GUIDE
CV Axle Bearing Press
This guide will show you how to use a hydraulic press to install an axle bearing into a spindle which holds a CV axle on either the front or rear of your vehicle. We are a...
2003 Ford Explorer Vibratiion
Hello, My Ford Explorer Developes A Smooth Yet Tight Vibration In The Steering Wheel Between 50 And 60mph. It's A Vibration Almost Like A...
Asked by
ctaylor3
2003
FORD EXPLORER
Explorer Wheel Bearings
I Just Took My 1993 4.0l 4x4 Explorer In For A Safety And Wus Told That I Needed To Change The Front Wheel Bearings. They Told Me That This...
Asked by
stanger987
FORD EXPLORER
2004 Ford Explorer Wheel Bearings
Drive Train Axles Bearings Problem 2004 Ford Explorer 6 Cyl Four Wheel Drive Automatic What Is The Estamted Repair Cost Of Repacking A...
Asked by
glm62r
2004
FORD EXPLORER
Are My Wheel Hub Assmebly Bad
I Have 1996 Ford Explorereddie Bauer 4wd And When I Put It In 4wd And 4low It Makes A Growling Nosie What Could It Be
Asked by
archieexplorer
1 ANSWER
2 IMAGES
1996
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Axle Bearing CV Bearing Replacement
Wheel Bearings and Seal Replacement
Online car repair manuals
