1996 Ford Explorer
WECONNORS
  • 1996 FORD EXPLORER
1996 Ford Explorer Automatic 104000 miles
I HAVE A 96 FORD EXPLORER. IT HAS 104,000 MILES ON IT. I HAVE NOT HAD ANY PROBLEMS WITH IT FOR OVER A YEAR. THIS MORNING I WAS NOT ABLE TO START MY CAR. I HAVE A BRAND NEW BATTERY, SO ITS NOT THAT. I LOOKED UNDER THE REAR BACK DRIVER SIDE AND SAW A BIG PUDDLE OF FLUID. IT SMELLS JUST LIKE GAS. IS IT A GAS LEAK? COULD THIS BE THE REASON THAT IT ISNT STARTING? IS IT EXPENSIVE TO FIX?
Monday, June 21st, 2010 AT 3:34 PM
  • 109,885 POSTS
It sounds like a fuel leak. When you turn the key on, the pump comes on and builds pressure. If there is a hole in the fuel line from rust or other damage, it will leak and if there isn't enough pressure to the fuel rail, it won't start. Try this. Have a helper turn the key to the run position while you check to see if gas is leaking under the vehicle. Protect your eyes. Because as I said, they build pressure fast and it could spray.
Let me know what you find.
Monday, June 21st, 2010 AT 10:39 PM
WECONNORS
Thanks for responding. I had a helper turn the key and press on the gas pedal while I watched underneath the car and it started spraying alot
Tuesday, June 22nd, 2010 AT 9:18 AM
  • 109,885 POSTS
That is the problem. What you have to do now is identify where it is coming from. Chances are it is the steel fuel line itself. They rust and eventually leak.
Tuesday, June 22nd, 2010 AT 6:50 PM
WECONNORS
Thanks
Wednesday, June 23rd, 2010 AT 6:43 AM
  • 109,885 POSTS
I'm happy to help. Let me know when you find where the problem was actually located.
Wednesday, June 23rd, 2010 AT 11:45 PM
