1995 Ford Explorer odometer not working
1995 FORD EXPLORER
125,000 MILES • 6 CYL • 2WD • MANUAL
CJJFLA
The odometer on my 1995 explorer has stopped working..the speedometer still works fine.The dealer says they can replace the odometer for about $600(not going to happen!)Internet research has indicated there is a small gear in the odomter that has probably broken and can be replaced..Questions...1)does this sound like it may be the problem and if so is it much of a job to replace these gears?.2)does the dash have to be removed and is that much of a job?
Feb 8, 2008 at 8:14 AM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
I sent some info your way via email...
Feb 8, 2008 at 9:11 AM
LUKE920
  • 10 POSTS
Anyone can teach me how to fix the odometer of my 95 ford explorer,2 WD, 139000mile, Please!
Just two days ago, I went to a transmission store since the 'overdrive' light flashing. They opened the hood and pulled out a cable connector then plugged in with their computer/meter to check the error codes. It seemed that they reset my truck's computer. Then my 'overdrive' light turned off. I drove away and found the odometer doesn't work anymore! I went back to them, thery told me they had nothing done with my odometer. Any suggestion???
Thank you very much!!!
Aug 12, 2008 at 5:27 PM
