1994 Ford Explorer wont pass brake inspection
1994 FORD EXPLORER
SNAKELADY19
Brakes problem
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic 200.00 miles
how do i inspect hydralic system, and replace drums and rear shoes, and top off brake fluid,
Jan 7, 2010 at 11:26 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
As far as checking the system, check all steel and rubber brake hoses to make sure there are no leaks. The master cylender is under the hood on the passanger side. Just remove the cap and fill it to the full mark with the appropriate brake fluid (DOT 3). Here is a how to for replacing rear brakes:
https://www.2carpros.com/how_to/rear_brake_shoes.htm
Jan 10, 2010 at 1:50 AM
