will not upshift ulless i take my foot off the gas at 2000 r.p.m. - 3000+when cold. it dos'nt do this for the 3-4&4-od shifts. downshifts ok. changed filter 3times [500 miles apart] dust level ok. can't find speck.s for band adjustment [2 bands].no vac. mod.,detent/kickdown cable seems to be adjusted correctly. no leaks,no sliping. i've pulled heavy loads wilh no problems execpt the shifting problem whitch happens loaded or unloaded. check engen light comes on but does not stay on & i can't get a code out of the computer for some reason. can't find any lose or broken wires/connectons/insolation anywhere. i'm told the tranz shifts by computer control do i have a bad sensor/sillonid?
Apr 18, 2008 at 5:29 PM
