1994 Ford Explorer Need a rough estimate
211,000 MILES • 4 CYL • 2WD • AUTOMATIC
DEREKG90
I need to know about how much it would cost including labor to replace the bushings on my car. I believe its on the front wheels only and is it something I should have replaced on both the front and back wheels?
Thank you
Jun 24, 2010 at 10:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
which bushing? front suspension has radius arm and axle pivot bushings while the rear suspension only has spring bushings..to get them all replaced will be around $250 in labor fees.
Jun 24, 2010 at 3:55 PM
DEREKG90
It might be both axle pivot and radius arm. It seems to make noise going over bumps and when I rotate the steering wheel. I not sure if that means its a mixture of both. Thank you for your help.
Jun 24, 2010 at 5:36 PM
