1994 Ford Explorer leaking in front part of transmission
730SOLO
  • 1994 FORD EXPLORER
Transmission problem
1994 Ford Explorer Four Wheel Drive Automatic
why would it leak from front part of transmission an not have power to move foward or backwards?
Monday, May 3rd, 2010 AT 2:02 PM
  • 109,885 POSTS
Is the leak between the transmission and the engine block?
Saturday, May 8th, 2010 AT 1:29 PM
730SOLO
No, from what I can tell it's not. The seal was replaced and it's leaking from there.
Friday, May 21st, 2010 AT 12:27 PM
  • 109,885 POSTS
Are you refering to the seal in the front of the transmission (front seal)? If so, that is what I was refering to too. Chances are the seal is bad again if they didn't replace the torque converter. The shaft on the converter passes through the seal and connects to the front pump. If the seal is bad again, something must be bad there. Often times, the converter wears from spinning against the seal. As a result, even a new seal won't stop the leak. Next concern is the not moving. If the front pump or the torque converter is bad, it won't move.
Let me know if the seal I'm refering to sounds like the one you had replaced. It will cause a leak between the trans and the engine.
Friday, May 21st, 2010 AT 8:10 PM
