1994 Ford Explorer engine starter
RED MOSQUITO 75
1994 Ford Explorer
My explorer makes a clicking sound when turning the key..Is it the starter and if not what else could it be?
Dec 30, 2009 at 2:47 AM
OBXAUTOMEDIC
  • 3,713 POSTS
Most likely it is the Start Relay Selenoid, it is located on the fender well near the battery, just follow the positive cable to it will only be about 6 - 10 inches away.
Make sure key is OFF. Then with a screw driver or something with an insulated handle touch it across the 2 large terminals. If it turns over replace that part.
Dec 30, 2009 at 2:54 AM
