"I haven't started it for awhile, and it is garage kept, and now I can't hear the fuel pump kicking in. "
"I also went under hood and switched the relays around to see if was big square relay, but still nothing. "
My guess:
Under the hood, on the passenger side, find the fuse box. Locate the fuel pump relay and tap on it a few times, lightly with the plastic end of a screwdriver, per say.
Since you said you haven't started it in a while, I'll guess at a low power situation happened.
If the battery is disconnected or low to dead, that relay will close, get stuck and not activatate the pump.
*Happened to me after an alternator went bad, changed it and then the fuel pump wouldn't run.
Hope that works for you.
SPONSORED LINKS
Monday, February 2nd, 2009 AT 1:00 PM
