1993 Ford Explorer my truck is acting like it not geting ga
84,747 MILES • 6 CYL • 2WD • AUTOMATIC
4THEFORD88
win my truck is in park it will run good it acts like it geting the gas but win i put it in drive it starts putting and acting like its not geting gas i dont thank it is the fuil filter.can you plez help
Aug 24, 2009 at 6:19 AM
  • 110,248 POSTS
Has the check engine light come on? Have you checked fuel pressure? Have you checked for vacuum leaks?
Sep 10, 2009 at 3:49 AM
4THEFORD88
no i have not cheacked the fuel pressure.but i did chang the plugs and put a new fuel filter on it just the other day. it started after we changed the transmission i was driving it the other day and i knowtist it starts off slow and win it hits 35 mph it will shift and it runs fine but after it gose down past 35 it stats doing it agen. it was sitting for like 1 year with old gas in it i was thanking maby the injectors needed to be cleand so i put some stuff called d-12 i n the gas tank and is still doing it.
Oct 24, 2009 at 4:45 PM
  • 110,248 POSTS
Start withhecking fuel pump pressure. THere could be a problem there.
Let me know what you find.
Oct 25, 2009 at 7:27 AM
