1993 Ford Explorer 6 cyl Two Wheel Drive Automatic
When I apply the brakes, they act normal until just before coming to a complete stop. Then the pedal begins to pulsate and a buzzing noise seems to come from under the dash every time the pedal surges. If I unplug the harness in the engine compartment, the brakes work fine, but the ABS light stays on. The pads, rotors, drums, and shoes are new. What could be causing this and is it something I can repair myself?
SPONSORED LINKS
Wednesday, April 1st, 2009 AT 6:54 PM
