1992 Ford Explorer starter does not disengageafter engine i
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
RICHARD RUVAL
after the engine has started the starter remains engaged
Jun 12, 2009 at 7:57 AM
TECHS IN
  • 14 POSTS
If the starter is staying engaged check to see if your ignition switch is sticking. If the switch is not sticking you have a solenoid problem. The solenoid is located on top of the starter. If the solenoid is working properly then the Bendix is hanging on the Armature. Both problems can be resolved by replacing the starter.
Jun 15, 2009 at 12:01 PM
