1992 Ford Explorer Brake Lights
1992 FORD EXPLORER
172,000 MILES • 6 CYL • 2WD • AUTOMATIC
KINIC
I just replaced the wiring harness for my brake lights because one of my brake lights went out. AFter doing the repair I now have tail lights but when I hit the brakes the drivers side goes out. I checked the harness and I have no frayed wires that I can see, none of my fuses are blown. I have no idea what to check next, please help.
Feb 13, 2010 at 7:57 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
With the new wiring harness, did you get new light sockets? Also, have you tried running a seperate ground for the side that doesn't work?
Feb 14, 2010 at 2:20 PM
KINIC
I did not get new scockets with the harnesses. My rear lights work it is just when I hit the brakes the drivers side goes out. Also how do I run a new ground on the drivers side if all wires are enclosed inside the harness?
Feb 14, 2010 at 3:44 PM
