Tires and Wheels problem
1992 Ford Explorer 6 cyl Four Wheel Drive Automatic
Are the wheel studs behind the roders. What is the best way to get the front wheel off if the studs are stripped and the lugs are still on it?
Monday, November 1st, 2010 AT 8:27 PM
BLUELIGHTNIN6
MECHANIC
If the studs are stripped then you will just have to twist the lug and stud off, since they are stripped they will need replaced any so doesn't matter if you twist end off or not.
