When I am driving and I hit 65 mph the vibration starts and will not stop until I drop down to around 55mph. The steering wheel is vibrating too.
Just had 4 new tires put on mounted and balanced. New brake pads and rotars turned on the front.
Mileage is around 152,000. Motor size is 4.1.
Sunday, November 18th, 2007 AT 5:47 PM
TOBYU
MEMBER
Did you hit anything with your old tires?
Sounds like a bent or damages wheel/rim.
Go back to the tire shop. It could be a bad tire. But unlikely if new ones.
They should be able to spot a warped or chunked wheel.
Monday, November 19th, 2007 AT 1:41 AM
VA DRIFTER
MEMBER
Thank You for the advice. I will have the tire shop check the tires and wheels. Again Thanks for the quick response.
