2001 Ford Expedition P1507 Idle Underspeed Fix
KALLINSTEVE
2001 expediton 85000
I got the code today. Auto zone doesnt know what it is.
The paper said Idle Air Control System Underspeed error. What does it mean. Thanks, Steve
Nov 17, 2007 at 3:20 AM
MERLIN2021
  • 17,250 POSTS
What it means is the RPM's are lower than the PCM wants, IAC valve or circuit should be checked, and or a clogged intake airway? how is your air filter?
Nov 17, 2007 at 3:39 AM
Suggested Repair
Check the idle air control (IAC) valve and its circuit, and inspect for a clogged intake airway or dirty air filter, since idle RPM is lower than the PCM expects.
Conversation Summary
A 2001 Ford Expedition owner received code P1507, described as Idle Air Control System Underspeed, and asked what it means. The expert explained that engine RPM is lower than the PCM wants and recommended checking the IAC valve or circuit and looking for a clogged intake airway or dirty air filter.
