2002 Ford Expedition heater problems
COALKINGS
  • 2002 FORD EXPEDITION
  • V8
  • 4WD
  • 160,000 MILES
The heater only blows warm air once in a while the temp gets to normal but does not overheat or blow warm air all the time. Have checked antifreeze it is not low. Any help would be great. Thanks
Wednesday, January 6th, 2010 AT 10:03 AM
88COOLJ
  • 6 POSTS
Does the rear heater get hot?
Wednesday, January 6th, 2010 AT 3:22 PM
COALKINGS
It is about the same
Wednesday, January 6th, 2010 AT 3:27 PM
88COOLJ
  • 6 POSTS
I am looking on the fourm and there are others including myself with this same problem. I did see something about the tempture control value? Not sure if this is your problem.
Does you engine temp run hot or cold? If cold, it could be the thermastat
Wednesday, January 6th, 2010 AT 3:34 PM
