2001 Ford Expedition PO171 OEM#
2001 FORD EXPEDITION
111,000 MILES • V8 • AWD • AUTOMATIC
01EXPEDITION
You just replied to me regarding this issue - thank you. I disconnected the positive battery cable for 20 minutes and reconnected it. The Service Engine Soon light went off. I did this because I was told I had to reset the computer because the light won't go out even if I fixed it. Is this true? Did I do wrong by disconnecting the battery? Will the light just come on again if I didn't fix this issue?
Thanks
Feb 5, 2010 at 8:43 PM
OBXAUTOMEDIC
  • CAR REPAIR CONTRIBUTOR
  • 3,711 POSTS
Yes you were wrong to do so, but not because of the possibility of the engine light coming back on. It is because you can cause a Voltage Spike and Fry your Computer. When you make a repair and need engine light turned off, just go by your local parts store and ask them to do it for you.
Feb 5, 2010 at 8:53 PM
