2000 Ford Expedition rear windshield wiper
2000 FORD EXPEDITION
KBMENCEY
Electrical problem
2000 Ford Expedition V8 Two Wheel Drive Automatic 200k miles
My rear windshield wiper works once in a while. How can I check to see if it's the wiper motor or the switch on the steering wheel ?
Mar 13, 2010 at 3:34 PM
  • 110,244 POSTS
Chances are both are okay. What I need you to do is remove the rear door panel and check the plug that supplies power to the motor. Chances are it is corroded and not making a good connection. Also, make sure the motor has a good ground. Often times from slaming the door shut, things come loose.
Let me know what you find.
PS: If everything looks good, make sure there is power getting to the motor using a test light, volt meter... If there is power and all connections are good, then you may need a new motor. If there is now power, check the switch.
Mar 22, 2010 at 6:38 AM
