1999 Ford Expedition brake lights do not work
1999 FORD EXPEDITION
130,000 MILES • V8 • AWD • AUTOMATIC
JEFFCASEY1996
None of the 3 brake lights work. The bulbs are fine and all the fuses are good. Does anyone know what the next thing to check would be? Trying to get this taken care without going to the repair shop.
May 12, 2009 at 7:52 PM
DOCFIXIT
  • CERTIFIED EXPERT
  • 18,828 POSTS
Hi
With all three out the brake switch up on top of pedal is the culprit. Check it maybe out of adjustment when pedal is depressed switch closes and turns on brake lights.
Thanks for donate
May 13, 2009 at 10:51 AM
JEFFCASEY1996
[quote:6b2db4247f="Docfixit"]Hi
Thanks for donate[/quote:6b2db4247f]
How would we be able to tell if the switch is just bad and needs to be replaced? How would we go about making an adjustment to the switch? We think that we have located where the switch is, but can't see how to adjust it or tell if it needs to be replaced. Thank you!
May 13, 2009 at 6:39 PM
DOCFIXIT
  • CERTIFIED EXPERT
  • 18,828 POSTS
Remove wirs jumper together if brake lights come on switch faulty.
May 14, 2009 at 8:19 AM
