1999 Ford Expedition BATTERY LIGHT
1999 FORD EXPEDITION
174,000 MILES • V8 • 2WD • AUTOMATIC
WRESPRESS
I HAVE REPLACED MY BATTERY AND ALTERNATOR AND BOTH TEST GOOD. MY BATTERY LIGHT KEEPS COMINAND THEN MY BATTERY GOES DEAD WITHIN 20 MINUTES. IF I MOVE MY (RELAY BOX?) AROUND THEN TE BATTERY LIGHT GOES OFF AND THE TRUCK RUN FINE. DO I HAVE A ELECTRCAL PROBLEM OR SHOULD I REPLACE THE (RELAY BOX?) IM NOT SURE IF THATS WHAT IT IS CALLED BUT IT SITS UNDER THE HOOD ON THE DRIVER SIDE AND IT'S A BLACK BOX.
THANKS FOR YOUR HELP,
WHYEETHIA
Sep 1, 2010 at 12:33 PM
SATURNTECH9
  • CERTIFIED EXPERT
  • 30,869 POSTS
If there is fuse's in there then that would be your under hood fuse box.Sound's like you have a loose wire that probably feed's the power to your alternator.That run's from that fuse box to the alternator.The fuse for the alternator is in the battery junction box it is fuse number 11 it's a 20 amp fuse when it's not charging and the light is on see if that fuse looses power you can use a test light to test that.
Sep 1, 2010 at 2:32 PM
