Seems as if there is an issue with the compressor that allows you to go 4H or AWD. Involuntarilly, the truck will make a horrible sound like a bad motor and within seconds the truck will slightly lift up on the suspension, usually only the right side. The sound goes off periodically, you can feel the truck lift up when you are standing in place. Could it be an issue with the 4wd selector?
SPONSORED LINKS
Thursday, November 27th, 2008 AT 9:25 PM
