Ok, first check the radiator to make sure there is enough coolant, if not fill with 50/50 diluted antifreeze/coolant. Have someone help you with that if you dont know how, because the engine should be running after you take the cap off and fill and it will go down then you fill again and keep doing it until it wont go down anymore, then the radiator cap goes on immediately.
Saturday, September 11th, 2010 AT 8:35 AM
