My speedometer recently started getting stuck at approximately 30mph, regardless of actual speed. If stuck when the ignition is turned off, it cycles back to zero but when the ignition is turned back on, the needle returns to where it was when the vehicle was shut off.
Not sure where to begin the troubleshooting process. Your guidance is appreciated. Thank you.
2004 Excursion Diesel 6.0 Eddie Bauer 4wd
Nov 3, 2008 at 10:57 AM
