2003 Ford Excursion OBD Realtime Sensor Data Not Communicat
2003 FORD EXCURSION
79,000 MILES • V8 • 4WD • AUTOMATIC
SYSBW1
I recently moved to CA where I need to have my truck smogged. Part of the test consists of a OBD diag and they are telling me there is nothing wrong, but the data from the OBD is not communicating with their computer. He said to drive it 50 or so miles, which I did and still no OBD results. Looking at his computer system, it looks like it cannot read realtime data. I have no problems with the truck, no check engine, no aftermarket accessories and no other problems to speak of. I am going to take it to another shop but at the end of the day, I am confused why the computer is not returning OBD information. Could the computer be bad? Could it be that they have a bad terminal to read my information?
Jul 30, 2010 at 8:16 AM
  • 110,244 POSTS
I would recommend checking the wiring harness to the PCM. Make sure it is clean, tight, and none of the pins in the plug have been damaged.
Let me know what you find.
Aug 18, 2010 at 4:38 PM
