2000 Ford Excursion trouble codes
SLUGGO39
  • 2000 FORD EXCURSION
2000 Ford Excursion Four Wheel Drive Automatic 56000 miles
what are these codes p1000, p0720, p0722
Wednesday, August 19th, 2009 AT 10:03 PM
  • 109,885 POSTS
P0720
Output Speed Sensor Circuit Malfunction
P0722
Output Speed Sensor No Signal
P1000
Check of all OBDII Systems Not Complete
I need you to disconnect the battery for about 30 minutes to see if it resets this. My guess is the output speed sensor is disconnected, damaged, or not working at all causing all of the codes. Reset the computer and see if the light resets with the same codes. Let me know what you find.
Wednesday, December 2nd, 2009 AT 5:15 PM
