2000 Ford Excursion Pulling to the right, sometimes with no
136,000 MILES • V8 • 4WD • AUTOMATIC
BEERYBOATS
Truck has been pulling to the right when braking with the occational groaning noise. It has had new or resurfaced rotors, aftermarket then oem pads, new shoes in rear, turned drums, all in the last two years. They tested front brake fluid pressure side to side, went back to oem pads in front and it will still dive to the curb when braking hard. The groaning noise is fairly new and not very often, but it sounds like it's coming from the right side as well. I'm thinking dragging rear drum brake. But it always pulls right for me, noise or no noise. My wife says she doesn't notice the pull, it's her car, but every time I drive it I feel the pull. I do drive more aggressively, hey I'm a guy, maybe that makes it more noticable?
Feb 18, 2010 at 9:21 AM
  • 110,248 POSTS
Do you have rear drum or disc brakes?
Mar 1, 2010 at 12:18 AM
BEERYBOATS
It has discs all the way around. It was really bad again this weekend, and then it quit doing it on Sunday. I plan on pulling a 30ft camp trailer with this truck and I'm scared to death this is going to happen when I least expect it.
Mar 1, 2010 at 9:25 AM
CASHWORTH
I HAVE YOUR SOLUTION! After 7 sets of rotors (each cut once), 4 sets of pads, new hubs, and new calipers (twice) - I found the solution...
I have a 2001 Excursion, and have had this problem for ever, and have tried every brand of high end rotors and OEM rotors. Every 5000 miles, I still got a brake job...
Here's the problem:
Ford put 16" rims on the EX so they could clear a 7' garage door. Notice how all the new truck advertisements are about big huge brake systems, and have 20" rims on them? SMALL RIM = SMALL BRAKE SYSTEM. Big Rim = Big Brake System.
What's happening is the system is overheating because it's too small, and is overheating the DOT3 brake fluid. The fluid is boiling, causeing the caliper to sieze on the right side, and sometimes the left. Mine was on the right more often... When you go to a shop to have the brakes looked at, their going to tell you that the right side caliper is siezed/frozen. Which it is, but relpacing just the caliper won't fix the problem.
After about $6,000 in brake jobs over 2 years, I had enough and did my research. Here's what you need:
2 new calipers - The right is siezeing, but like rotors, you replace these in pairs. 2 new rotors - don't go cheap, but you don't need the best. Buy a "good" set of rotors and pads. I bought from frozenrotors.com. Read about them - kinda cool... 2 new front brakes hoses. The brake fluid overheating has broken down the rubber lining.
Now, most importantly, and fortunately the least expensive - Get the brake fluid flushed with DOT4 brake fluid, not DOT3. DOT4 has a higher boiling point, and won't overheat/boil, therefore, won't kill your new calipers. The DOT3 is boiling and killing the calipers, and thus - the rest of the system. Yes, DOT5 and 6 is even higher, but their synthetic, and you can't use synthetic in this system. It's will kill your ABS system.
Now you're telling yourself, this is going to be expensive! Well, yes it is, but you bought an EX, life goes on... You can go cheap, but learn from my mistakes... If you go cheap, you will keep replacing stuff.
I've had these brakes on for almost 20K, and no problems. I should mention I pull an 8000lbs 32ft camper w/ double slideouts, and a 9000lbs, 32ft boat.
on another note - get the weight distro hitch and sway bar for your new camper. Because the steering is already sloppy on the EX, you want that camper sitting tight on your hitch.
Your Welcome....
Mar 20, 2010 at 10:48 AM
BEERYBOATS
It makes total sense to me. The sounds are getting worse every day. But towing is a breeze with the trailer brakes. No pulling with the trailer acting as an anchor. Thanks, Jay
Mar 20, 2010 at 1:37 PM
CHETEMMA
New to this site......You have no idea how great it is to find this answer......now question. I replaced rotors pads calpers all oem 5000miles or so on them. Intermittent pull to the left dangerous and totally unpredictable. If i dont fix truck is leaving and i looked for years for this truck. So I am spending money anyway so am I better off to go on to "big brakes aftermarket" and big rims my expedition has 20" and I am going to look at brake size on it to see what Ford did there. Tires and rims big bucks so perhaps in two hits first retrofit brakes tires and rims later. Always wondered why the small tires on Ex. CASHWORTH any other words of wisdom on crappy suspension on 140.000 miles on a 2001. They are telling me springs are gone all other suspension has checked out want to keep this truck but it drives poorly on all but perfect roads and the above brake issue pushing me toward selling a rare totally stock truck owned by a state EMA
Nov 30, 2019 at 11:08 PM
