2000 Ford Excursion
EXCURSION
  • 2000 FORD EXCURSION
  • V8
  • 4WD
  • 82,000 MILES
The vehicle radio stays on all the time, even when the vehicle is turned off and then runs my battery down. Can you please advise me as what to check for this problem? Thank you
Monday, December 1st, 2008 AT 1:07 AM
DAVE H
  • 13,384 POSTS
Does the radio stay playing? Or is it just lit up when when you turn ignition off? If it continues to play. Check ground point G203 behind right kick panel, for break in wire between ground and radio black/light green wire . If it just illuminates. Check ground point G206 behind the center of the dash black wire.
Monday, December 1st, 2008 AT 5:59 AM
Related Radio Stays On Content
