When I push the clutch in, the car cranks.
KYLE.KIMBLE
I own a '93 Ford Escort GT with 300,000 miles and a 1.8L engine. It's a 5 speed.
About a week ago, I left my lights on for a couple hours and killed the battery. I tried to jump it, but had the jumper cables switched (+ to - and - to +) not longer than a couple minutes. I eventually got the battery charged. I looked, but couldn't find any blown fuses.
The card drove fine for a couple days, then it started not cranking on the first try. The other day, I went out and kept trying to crank it, then something changed. Now, when I push the clutch in (whether I turn the key or not or even have a key), the car cranks and starts. This still happens when the car is started, so I can't put the car into gear. Also, after turning the car off, I found that I could put it into any gear without pushing the clutch in.
Do I have a bad Starter Motor? Clutch? Ignition Switch? Something else?
Thanks a bunch,
Kyle
Nov 20, 2007 at 3:16 PM
2CARPRO JACK
  • 11,533 POSTS
See if you have a starter relay, if so it could be stuck on. Otherwise the starter solenoid is stuck.
Nov 21, 2007 at 3:43 AM
KYLE.KIMBLE
Thanks a bunch.
Nov 21, 2007 at 8:14 AM
