2000 Ford Escort Keyless Entry Add-On
JWADE
I have a 2000 ford escort sedan. It is equiped with powerlocks and windows.Is it possible to add keyless
remote to this car?The power locks are OEM. Thank you.
Oct 28, 2006 at 11:40 AM
NOS
  • 320 POSTS
have you asked any dealer if it already had this type equipment on it ? i'am sure it can be done but i belive it is expensive the pass key pad has to be able to send a signal to the door lock module so it can send voltage or a ground to the locks. my suggestion to you is take it to a aftermarket place where the do keyless entry and just have it priced.if you don't have much know how on it i wouldn't tackle it would causemorr greaf that you could even know if you hooked up a wrong wire some where you could fry your whole wiring harness.(NOS) 8)
Oct 28, 2006 at 12:31 PM
JDKELLEY
Any vehicle with power locks can be connected to a keyless entry system. With a circuit tester light, it's quite simple. There are "Do-it-yourself" kits that are affordable. Check your local O'Reilly's Auto or Autozone. You can pick one up for about $50 or $60. As I said, it's fairly simple, but can be time consuming. To do it yourself, be prepared for the job to last a couple of hours, if not more. The key fobs that come in the kits can be programmed to the system you install. The best kit I have found, so far, is made by Bulldog Security. You can check out their website, too. www.bulldogsecurity.com
Jan 13, 2007 at 6:10 AM
Suggested Repair
Have an aftermarket shop price and install a keyless-entry system, or use an affordable DIY kit such as Bulldog Security if you are comfortable with wiring. Confirm whether the car already has related equipment, and avoid DIY wiring if inexperienced because a wrong connection can damage the harness.
Conversation Summary
The owner of a 2000 Ford Escort sedan with OEM power locks and windows asked whether a keyless remote can be added. One reply said it is possible but potentially expensive and recommended an aftermarket installer rather than DIY wiring, warning that a wrong connection could damage the harness. Another reply said any vehicle with power locks can accept a keyless system and suggested affordable DIY kits from auto parts stores, including Bulldog Security, noting the job can take a couple of hours.
