1998 Ford Escort Hard Start
STEVESTONE1364
I have a 98 ford escort 2.0 SOHC, with 150k miles. The car is hard to start on the first try. It will usually start on the second turn. after I drive and let it sit it will crank on the first try. Or if I turn the ignition back and forth a couple of times (without cranking the car over) it will start up in the first try. I can hear the fuel pump come on when i turn the car over. These are new: plugs, wires, timing belt, both coolant sensors, put fuel injection cleaner on the last two fill ups, thermostat, water pump, just flushed the coolant system. Car runs perfect, no hesitation, and idles fine. Any help would be very
Oct 19, 2006 at 2:21 PM
CATCH_15
  • 250 POSTS
Even though you hear the fuel pump doesn't mean it's not about to go out. If you've replaced everything you say you have, it sounds like you have a weak fuel pump and need to replace it.
Oct 20, 2006 at 3:36 PM
Suggested Repair
Replace the fuel pump. A weak pump can cause hard starting even if it is heard priming.
Conversation Summary
The owner of a 1998 Ford Escort 2.0 reports that it is hard to start on the first attempt but usually starts on the second crank or after cycling the ignition. It runs and idles normally after recent ignition, cooling, and timing work. The expert suspects a weak fuel pump and recommends replacing it.
