2002 Ford Escort
NIKKIFLO
  • 2002 FORD ESCORT
2002 Ford Escort
My gear will not come out. I can start the car, but when I step on the break to put it in reverse, it won't move. It's stuck.
What can I do to fix the problem.
Thank you
Nikki
Tuesday, April 29th, 2008 AT 11:41 PM
LEGITIMATE007
  • 5,121 POSTS
Take a look at the park neutral switch on the transmission, just follow the linkage from the shifter. It may be stuck. Spray some wd40 on it and work it. Or you may need to replace it. Is your shifter on the floor?
Wednesday, April 30th, 2008 AT 5:14 AM
