2001 Escort/ZX2 temp guage
RADAMS845
My Temp gauge bottoms out past hot. When first turned on and even when turned off, it only goes a bit past the hot towards cold. It has 105,000 miles. Also, I cannot tell if my fan is kicking on. I replaced the 40A buss fuse already, just in case. Let me know if you know what else I can look for. I made sure the radiator fluid was full, and it was.
Thank you,
Rick
May 30, 2007 at 12:55 PM
CRAIGFL
  • 89 POSTS
Fords have lots of trouble with temp gauge senders. Make sure you find the right one(usually there are two--one for the gauge and one for the engine management systems) and replace it.
May 30, 2007 at 11:50 PM
