2000 Ford Escort ZX2 Car Stalling and Dying/Rough Idle
TGRUTZMACHER
  • 2000 FORD ESCORT
  • 4 CYL
  • MANUAL
  • 11,500 MILES
My car seemed to be running smooth until one morning on the way to work I stopped at a light and it died. It kept dying at each light. Started back up just fine. Check Engine light came on codes indicating a code error for the TPS, and the code was P3183, (I think that was it) which my mechanic said was the Camshaft Position Sensor. My mechanic replaced both as well as the fuel filter. To no avail. It's actually worse now. The car used to idle ok, but now it idles very roughly, and it stalls not when the engine is cool, but when it warms up. Any suggestions?
Tuesday, January 27th, 2009 AT 8:41 PM
BMRFIXIT
  • 19,053 POSTS
Check timing and idle air valve
check for vacuum leaks and intake manifold gasket
do u still have check engine light on
and if so scan for codes again
and let me know
Wednesday, January 28th, 2009 AT 5:38 AM
