2000 Ford Escort timing belt idler pully
2000 FORD ESCORT
NVFAMILYMECHANIC
Engine Performance problem
2000 Ford Escort 4 cyl Front Wheel Drive Automatic
had to repair damaged threads the problem is that i r might of made the hole to big for the heli-coil to fit. There no threads for it to grab on to.Is there any thing i can do to make it smaller and re-thread it
Aug 22, 2009 at 6:32 PM
BMRFIXIT
  • 19,053 POSTS
I dont believe going bigger going to help
best is to keep it at the same size check heli-coil repair kits
if to drill mark the drill bit so you dont drill deeper than needed
good luck
Aug 23, 2009 at 12:27 AM
