2000 Ford Escort
FUNTOWN4
  • 2000 FORD ESCORT
  • 4 CYL
  • 104,000 MILES
I have a 2000 ford escort zxt the fan works but no heat comes out what could be the cause of this problem.
Saturday, December 6th, 2008 AT 8:28 AM
BMRFIXIT
  • 19,053 POSTS
Check thermostat
does the engine reach operating temperature
if not check and replace the thermostat
its located under the coil pack
remove coil pack for easier access to thermostat housing
housing held down with 3 bolts
if its reaching operating temp
Check heater core hoses if both are hot, if not the heater core need to be flushed
these are the steps
WARNING: NEVER REMOVE THE PRESSURE RELIEF CAP UNDER ANY CONDITIONS WHILE THE ENGINE IS OPERATING. FAILURE TO FOLLOW THESE INSTRUCTIONS COULD RESULT IN DAMAGE TO THE COOLING SYSTEM OR ENGINE AND/OR PERSONAL INJURY. TO AVOID HAVING SCALDING HOT COOLANT OR STEAM BLOW OUT OF THE COOLING SYSTEM OR DEGAS BOTTLE, USE EXTREME CARE WHEN REMOVING THE PRESSURE RELIEF CAP FROM A HOT COOLING SYSTEM OR DEGAS BOTTLE. WAIT UNTIL THE ENGINE HAS COOLED, THEN WRAP A THICK CLOTH AROUND THE PRESSURE RELIEF CAP AND TURN IT SLOWLY UNTIL PRESSURE BEGINS TO RELEASE. STEP BACK WHILE THE PRESSURE IS RELEASED FROM THE COOLING SYSTEM. WHEN CERTAIN ALL PRESSURE HAS BEEN RELEASED, PRESS DOWN ON THE PRESSURE CAP (STILL WITH A CLOTH), TURN AND REMOVE PRESSURE RELIEF CAP.
Engine cool
lower the coolant level
Locate the two hoses running to the heater core
disconnect them at the engine side leaving hoses connected to heater core throw the firewall
use garden water hose and compressed air if possible
run the water and follow by air throw one side and out the other and vice versa
do that two to three times watching what leaving the heater core you are looking for the good flow and clear water to run throw
reconnect hoses
top off coolant system
if both hot check blend door and valve
good luck
let me know
Sunday, December 7th, 2008 AT 9:54 PM
