Your vehicle is obd II so you cannot change the idle speed of the vehicle, the computer controls that based on set presets.
You can try to change it a bit if you have a screw in the throttle body to change the throttle plates open or closed to raise or close idle. But doing that may mess with the idle control system.
SPONSORED LINKS
Wednesday, January 27th, 2010 AT 6:12 PM
