1999 Ford Escort
115,000 MILES • 4 CYL • FWD • MANUAL
SHIFTYCAPONE66
I have a whistling noise,it sounds like a pulley squealing. I can turn the car off,and it continues awhile after,fading off till its stops. The noise doesn't seem to go faster with acceleration, just get's lower. I believe it has too do with an air leak,but I'm not sure. I had a local mechanic look at it, he stated that it was exhaust related. I had both tentioners replaced so that's not it. The water Pump is new. I just had both Timing belts replaced. I am at a loss...I just can't narrow down exactly where it's coming from. If it is exhaust related, how do you find such a small leak? Please Help!
Jul 11, 2010 at 1:52 AM
2CARPRO JACK
  • 11,533 POSTS
Look for black soot (exhaust) coming out of where you suspect the leak could be.You can also roll up a rag and wedge it in the tail pipe then start it, this will intensify the leak so that you can find it easier
Jul 12, 2010 at 6:43 AM
