Vehicle idles rough. When first turned off I hear the gurgling in gas tank. I have cahnged both O2 sensors, plugs, wires, fuel and air filters. I also turn key on and off several times to get atart on first carnk. When not running there is no fuel in fuel rail. I'm guessing it is going back into tank. Is there a pressure regulator or should I cange the pump? Thanks for the help.
SPONSORED LINKS
Monday, September 13th, 2010 AT 12:28 PM
