1998 Ford Escort My car died while I was driving
RAE2009
  • 1998 FORD ESCORT
  • 4 CYL
  • FWD
  • 159,000 MILES
I have a 98' Ford Escort Sport. I was driving on the expressway yesterday going about 70 mph and my car just died. I pulled over and when I tried to re-start it, it turned over but wouldn't start. What could my problem be?
Friday, February 13th, 2009 AT 11:25 AM
BILLYMAC
  • 2,204 POSTS
Hi could be a timeing belt broke. Remove upper timeing cover bolts pull cover out a little see if belt is on cam. If so have someone crank eng carefully look and make sure belt is turning if yes belt is ok. Next check for spark remove plug wire ground to the eng. Crank if yes spark. Check fuel pressure at the rail. Billymac
Friday, February 13th, 2009 AT 3:53 PM
