Certainly can. Owners manual dont describe it much anyways.
Start the vehicle and while it is running you should pull a fuse for the fuel pump, if not you should disconnect the fuel pump shut off/inertia switch.
Then you should continue to crank it after it dies for say 20 seconds. Do this a few times with pauses inbetween.
Pressure should then be gone.
SPONSORED LINKS
Friday, June 6th, 2008 AT 7:17 AM
