1998 Ford Escort Car Turn Over with Clutch down But won't C
YOLOVE61
MEMBER
1998 FORD ESCORT
4 CYL
2WD
MANUAL
164,000 MILES
Car turn over untill Battery Dead I heard a Noise in the Clutch As I hold it Down But It will NOt Crank
Wednesday, March 18th, 2009 AT 11:43 PM
ZACKMAN
MECHANIC
Probable fuel delivery problem. Can you hear the fuel pump turning on? Check voltage at B+ connector on the fuel pump wire harness. You may want to check fuel pressure at the fuel rail. Fuel pump relay, as well.
