i took it in to get repaired and the mechanic replaced the fuel filter and fuel pump. It seems as if those changes helped alot with my fuel pressure, however, it continues to shake and struggle when accelerating. The mechanic said last night when I picked up from its previous repairs "it looks like the fourth cylinder is having problems. But it is drivable enough to use this week." I am thinking the problem could have something to do with my spark plug. However, I am not sure which one is the fourth cylinder's plug.
if I were looking at the engine from under the hood, which spark plug would be the fourth cylinder?
this is a very cheesy diagram of whats under the hood but could you basicaly label the blanks of which cylinder is which.
ex: _ _ _ _ 4 3 2 1
inside of car
engine
_ _ _ _
front of car
and if possible if you dont think this is the problem, any ideas on what might be wrong?
SPONSORED LINKS
Wednesday, February 18th, 2009 AT 10:42 AM
