1998 Ford Escort ALTERNATOR BELT
RAW_76
  • 1998 FORD ESCORT
1998 Ford Escort 4 cyl Front Wheel Drive Automatic
HOW DO I PUT ONE ON THE FORD ESCORT 1998
Friday, October 23rd, 2009 AT 6:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Depends on which motor. This is for the 2.0L SOHC engines
REMOVAL:
Insert a 3 / 8 in. Drive ratchet or a breaker bar in the hole on the automatic tensioner, then pull the tool toward the front of the vehicle.
While releasing the belt tension, remove the drive belt from the tensioner pulley and slip it off the remaining accessory pulleys.
INSTALLATION:
Position the drive belt over the accessory pulleys.
Insert the 3 / 8 in. Drive ratchet or breaker bar into the hole of the automatic tensioner, then pull the tool toward the front of the vehicle.
While holding the tool in this position, slip the drive belt behind the tensioner pulley and release the tool.
Remove the tool from the automatic tensioner.
Check that all V-grooves make proper contact with the pulley.
Friday, October 23rd, 2009 AT 7:55 PM
